Solid Propellent Rocket Engine in Trainer!!!
Okay just a thought but wouldn't it be a gas to install one of the solid propellent rocket engines in a trainer or strap one of the rockets to the underside of a plane and lift it with another plane and let it glide down then igniting the rocket motor while pointed up?? Think I saw it done in a video here but not sure...Whats everyones thoughts??
RE: Solid Propellent Rocket Engine in Trainer!!!
Some will claim "inovation" and explore new ideas etc..etc.. But overall it is a bad idea that has been talked about here many-many-many-times over.
Just go someplace where no one can get hurt and nothing can catch fire..
My Feedback: (41)
ORIGINAL: tommy157
You will get plenty of negitive comments about this. I have used RATO on two planes. NO I did not burn anything down, NO I did not do this at an AMA field. Yes it was safe. Estes was making and selling a rocket powered glider for a couple of years.
I am not an AMA expert, so do not quote me. The one item I remember about the rules is that the solid rocket body has to stay with the aircraft. The rocket engine for the rocket powered glider did not have a charge to deploy a chute so they just stayed insdie the fuse.
From memory the thrust line of the rocket has to point through the center of gravity of the aircraft.
Try doing a search on RATO and JATO or rocket assisted take off.
Dru.
Dru.
Well, so long as the rocket stays attached to the model, or the rocket is flown in accordance with the NMRA safety code you CAN fly your idea at an AMA field. Only thing restricted by the safety code is launching against a ground or air target.
Trouble is most model rocket motors are very small and short burning relative to the mass of an RC airplane So you will see a little PFFFT of smoke, and not much acceleration out of your airplane. No flames just smoke.
Just be safe
Tom AMA CD 8026
Just be safe
Tom AMA CD 8026
My Feedback: (26)
ORIGINAL: MajorTomski
I think you just made "MT's" case.... the model X1 is small and very lightweight. thats why it looks so 'impressive'.
We can do the math later but a Estes "D" size engine has about 30N of thrust. Thats about six max thrust pounds. Sounds impressive right! (wrong). When you account for the size of a model trainer the overall acceleration force is not that great.
That is why the only practical application for small solid rocket engines in RC has always been with small gliders. I guess you could strap several engines to a model trainer- But again the extra battery weight+engines would make the overall net effect inefficient at best..
NJ
