Monokote Trim
GA
Monokote Trim
Any advice on how to use Monokote as trim? I am getting ready to cover an ugly Stick and was wondering about techniques for putting the trim on. I am considering covering it in Monokote and want to put the white stripe on the fuselage and the wing. Can you put Monokote over itself without bubbling? Any ideas would be appreciated, thanks.
Will
Will
My Feedback: (-1)
CA
RE: Monokote Trim
I just did two 4 inch stripes of monocoat trim over oracover. Windex, a credit card to squeegee out all that you can, let it dry and then touch the edges that lift with an iron set pretty low. Not a bubble to be seen even in 116 degree weather.
