what type of paint should i use...
RE: what type of paint should i use...
Since it is fiberglass a good part of your problems are solved.
First, I would CAREFULLY sand off as much of the original paint as possible. DO NOT SAND TO THE FIBERGLASS - leave a little of the original paint/gel coat there. DO NOT USE A PAINT STRIPPER. The majority of the strippers WILL DAMAGE the fiberglass.
Then I would prime it and paint it.
The type of paint you use will be determined to a great extent by whether you are using glow power or electric.
On a personal level, I like and use latex paint. Latex can EASILY be mixed for an EXACT match to existing colors (just bring a sample to the paint store ). This does require spray equipment to do the job properly. Latex USUALLY takes 7 - 10 days to "cure", but can take longer depending on the temperature and humidity. Latex is lighter in weight than enamel or lacquer when dry/cured. I STRONGLY suggest using a white primer as your lighter colors (yellow, cream, etc ) will cover it in fewer coats. You can also use spray bombs of Ultracoate or LusterKote (ugh ).
If the plane is electric, that is all you need. If the plane is glow powered, you will need to clearcoat the latex with a waterbase polyurethane or something like Ultracote clear to fuel proof it.
