First time w/ gasoline
WA
Doe's anyone know if the hayes fuel tank o-ring seal will work with gasoline? also, whats the best way to set up a tank for gasoline (venting) I'm thinking a one way check valve to allow air in . Also will the engine stop like a glow engine when the carb is closed off ? should I install a kill switch ? shure would would like all's input on this Thanks Bob
My Feedback: (33)
RE: First time w/ gasoline
As for setting up the tank i just run the vent line out the bottom of the fuse , preferably in a place that you can see fuel come out of it when your fueling so you'll know when the tank is full. You dont need any check vavle or anything.
Just set it up the same as your glow tank and run the vent out the bottom of the plane instead of to your muffler.
Unless your tank says in the instructions that came with for use with gasoline you will have to buy a conversion kit for it.
The engine will stop when the carb butterfly is shut all the way, however you still need another way to shut that thing down. I use a servo on the choke for this purpose this gives me 2 remote ways to stop the engine. You dont want to try and fly that thing out of gas if your throttle servo deciede to quit for some unseen reason. So yes you need a cut off of some sort other than the throttle servo!
Chad
Chad
My Feedback: (33)
I dont know if you must have an ignition kill switch ? I think that either and or will work just fine! As long as you have 2 ways to remotely kill the eninge.
Chad
Chad
IL
I've the pile of junk not having an ignition kill switch created with a Ziroli P-38, when one motor stuck at 1/2 speed, and the other motor quit.
The throttling option is only second best to a guaranteed shutoff with a kill switch.
IL
Ignition Kill Switch = must have item.
Lets check the compression, BAM, oh s@#$ - help, anybody got any bandages?????????
or maybe
Kid comes walking thru pits. Nice big prop to flip. You later ..... Judge, that thing never has started on the first flip before in its life.
Simple to install and cheap, no reason not to have one.
Ed M.
or maybe
Ed M.
My Feedback: (33)
Well of course you have to have a switch on the outside of your plane to turn the ignition off on while it is in the pitts or strorage , but you dont have to have a remote ignition switch.
I think it would be common sense to have a switch on the battery! And while your at it go ahead and put one of those nice JR charge switch jacks so you have a convient place to charge.
Chad
Chad
IL
or maybe
or maybe
IL
I believe part of this thread was in reference to methods of killing the engine from the Tx. I would think a manual battery switch for the ignition is common procedure.
Wasn't my plane. MOF it was on it's first (and only) flight, when the throttle (servo?) jammed or disconnected with the motor at 1/2 power. When the 2nd motor quit, it went in.
The builder made up another one, and it too went in due to power asymmetry.
That was his 3rd in a row. The first one, a smaller version, dove in on its first (and only) flight.
P-38s are not good airplanes, either model or full-scale.
Were I to build a large gas twin, I'd have both the ground reachable ignition cutoffs on both motors, and the remote cutoff.
Scale twins are just nasty airplanes unless they're very carefully chosen.
IL
Hiya Bob.
The ignition coil on your engine will have a wire ,single wire coming out.Thats the kill switch .If you groud it against the cylinder or any other part of engine(except carburetor) yoru engine will die.-thats an ignition kill.Possibilities are endless.You can rig the switch to the gear channel or just have a sitch outside the cowl.As for closing buterfly it will work as well.You can either close the butterfly or close the choke-both will kill.
Hows the weather in WA?
WA
Hey mitty got a kill switch on its way guess i will set it up to kill both ways seams to be the way. now to figure out the fuel tank system Seams to me if you leave the vent line dangling flying inverted will cause a serious fuel leak problem. Maybe I just don't see the picture yet.
IL
hey bob i'm new to gas planes aswell, and i asked that same question and the answer i got was that the engine pulling fuel from the tank which would keeep a steady airflow into the air vent to displace the fuel being removed from the tank, they told me a little might come out, anyway sounded good to me.
With a 2-line tank. one for fill-vent, the other to the motor, the motor drawing fuel sucks air into the tank via the fill-vent line. There can't any outflow with the motor running.
With a 3-line tank, 1 for fill, 1 for vent, 1 to the motor, the fill line tube inside the tank goes to the bottom of the tank. The vent line goes to the top. When fuel comes out the vent line while filling, the tank is full.
In flight, both fill and vent lines will supply air to replace the fuel the motor draws from the tank. Spilling out either line in flight is unlikely, and in any event, plugging off one or the other makes that impossible.
IL
Okay guys, call me paranoid, but I still use two receivers on my big gas birds. If it is mag fired, I use the Great Planes switch unit. it has two switches in series. If either is opened, the engine dies. One mounts to the side of the plane for manual use, the other gets connected to a mini or micro servo for transmitter electrical kill. I usually use the retract channel on my computer radio to set it up on the spring loaded trainer switch, and plug it in the left receiver. The right receiver powers the throttle servo and the throttle kill percentage rate is set for the same sping loaded switch on the transmitter. Now, if I have a battery or switch failure on either receiver system, I still can kill the engine. A big gas plane can do allot of damage if it becomes uncontrollable, so being a former safety engineer, I get a little carried away. But better safe than sorry.
IL
