New Covering
New Covering
I have a Sig Morrisy Bravo that has a very bad automotive paint job on it. I don't know if the fabric is iron on or glued. You can see my RCU listing for it. I think I might just keep it and recover it. BUT??
How do I pull off the old covering without pulling balsa off?
Thanks!
Howard
Thanks!
Howard
FL
RE: New Covering
Heat and peel. If it's a doped on covering then just peel. Always peel straight back over itself so that there is less potential for damaging the airframe.
RE: New Covering
Thanks, I thought a heat gun might do the trick!
I mispelled the name of the airplane. It is a Sig "Morrisey Bravo" and it is still on RCU if you want to check it out.
Thank you again!
Howard
Thank you again!
Howard
