Fueling help!!!
RE: Fueling help!!!
As I recall, within the last year, Slimline brought out the first one ever available (that I know of.) If you're speaking of gasoline, your choices are limited.
Sometimes, people say "gas" and really mean "glow." There are other options for glow fuel. I did not assume you meant "glow."
Good luck,
Dave Olson
Good luck,
Dave Olson
ORIGINAL: laz51
I am looking for a electric fuel pump for gas but I do not want to spend a large amount on one Thanks
RE: Fueling help!!!
Hi, i work at Advance auto parts and we sell some universal electric fuel pumps from purolator for pretty cheap. I have no idea if around 20 bucks is cheap or not, sorry im very new to flying. They are 12 volt low pressure, about 1 to 4 psi or more if u want. they have npt threaded ports and a they even come with a few brass fittings to hook up some line to them. even have a small base to them with some holes that would mount real nice to a field box. i have no idea if this will help but i thought i would give it a try. cya, Dave
