glueing sheeting togeather
KS
what is the cleanest way to glue sheeting together
so you do not get glue on the covering side of the sheeting
i used thin ca and that gave me a hard spot that i cant sand
any good info
thanks
any good info
thanks
RE: glueing sheeting togeather
Trim the edge of both sheets so you have a perfectly square and straight cut. Put 1" wide masking tape lengthwise holding some pressure so the edges are tight. Turn over and bend 45 degrees. Use a small diameter of titebond or white glue on the edges. Straighten out the glued sheets and use a credit card to wipe off the excess. I then cover mine with wax paper and lay a glass shelf on top.
Just how I do it. White glue sands well and the glass plate keeps the sheeting even.
John
John
RCU Forum Manager/Admin
My Feedback: (9)
As Warren said, use carpenters glue to join sheeting. Apply glue to the edges of you sheeting and join them together. Wipe any excess glue from the joint. Use some wax paper or vinyl sheeting to protect the sheeting and place some weight on top of the joined sheeting to keep the joint flat. allow ample time for the glue to cure.
