can anyone help with repair?
IL
I have a couple hobbico battery powered planes here and they all have at least one thing wrong with them. my question is does anyone know where I can get some information on the little circuit boards that power these planes. one of them is just not picking up the signal from the radio and I am sure if I knew what I was doing it would be a simple fix. I am just looking for something that shows me what all the little resistors and things do on them.. thanks
FL
RE: can anyone help with repair?
If you didn't break it then you should probably send it back. Nowadays there is so much surface-mount technology that home repair is pretty much out of the question. Most of our electronics are so inexpensive it's cheaper to just replace them.
