OS 7D Carby
OS 7D Carby
I have a venerable OS 91 (FSR I think) ith a 7D carby.
The slow running needle is not the usual type with a screwdriver slot. It seem to have a small plate (flat against the side of the carby) which is located by a grub screw.
I beleive that to adjust slow running mixture, you turn the grub screw, which has an eccentric which moves the plate round,
Is this right? Does anyone know which way you turn the screw to lean the mixture?
RE: OS 7D Carby
Thanks Bax
Will try that next time I get to the field.
The weather here in the UK in very mild for the middle of winter (45-%) degrees F) but often too grey to want to go flying.
david
david
