sig aerokote\ topflight monokote
i have been building kits for only about 5 years. i have tried several kinds of covering. i found that mono kote works best for me. i ran out of covering on my kit that i am building and had to use some sig aerokote . i found that it tightens up so fast with such little heat that it would pull apart at the seams. would like to get other opinions before i try to make any of my own. i am a little impateint sometimes and maybe it was just me putting to much heat on the low heat covering. any advise on this product will help. i did use a tempature gauge as the covering called for. about 200\250 degrees. thanks. charles
