Reload this Page >
GP DR1 & Saito .80 eng.
Old 09-21-2002, 01:33 AM
Flyguy1791
Default GP DR1 & Saito .80 eng.
Have a question on prop size for the saito .80 . The paperwork calls for a 11-8 prop but on the Red Baron Tri-plane the cowl is almost 9" in diameter.
When I tried to fly it with a 13" prop , it got air born and seemed to stop in flight and hover like it was needing some serious power. The plane calls for a .80 4-stroke max and everything hits right with the CG.
What would happen if I put a 14" prop on it and should I try a smaller 11" prop that it calls for from manufacture?
Thanks for any suggestions.
Tony
Old 09-22-2002, 12:55 AM
ajcoholic
My Feedback: (10)
I have a saito FA80, usually run a 12-8 or 13-6 but it will easily haul a 14-5 or 14-6 prop, even try a 15-6, no kidding! I run a 15-8 on my OS.91 FS and it loves it. Four strokes dont mind lugging extra prop as a 2S does (and will overheat). The plane is draggy and you dont want a high pitch prop, go for a lower pitch, larger diameter. I'd try the 13-6 or 14-6.
AJC
Old 09-23-2002, 01:59 AM
Flyguy1791
Default saito .80 prop
Thanks AJ . will definately try
