Robart Air Pressure
MN
Robart Air Pressure
How much air pressure do you use for Robart retracts? Also, if I add 20 to 30 lbs one day should there be pressure in the system the next? (worring about leaks)
thanks again,
Sheldon
thanks again,
Sheldon
My Feedback: (9)
FL
Robart Air Pressure
I've never had a system that didn't leak, at least some.
The answer to your question is no, probably not.
I have a Ziroli P40 that has the large capacity tank in it and it leaks at an approximate rate of 30lbs to 40 lbs in the first hour.
When the pressure is lower, at or around 40lbs it takes a few hours to dissipate, but never holds for entire overnight duration.
Robart Air Pressure
I have a Bert Baker P47 with Robart gear, including a large Robart tank. I usually air it up to 100-110psi. After four or five days it still has enough pressure for several cycles. Leaks should not be 30 to 40psi an hour, that should be easy to find with a bottle of leak check.
Vince
Vince
My Feedback: (9)
FL
Robart Air Pressure
So what am I doing wrong? I have a Ziroli Corsair, a Ziroli P40, an American Eagle Dc3, a Vailly FW 190, and not a single one will hold air for hours, let alone days.....
Just my experience.........
Robart Air Pressure
The two biggest areas I have found for leaks other than the tube connections are the o-rings, keep them lubed with vasoline once a season, and the retract valve, make sure it moves only enough to cycle the gear, also check that the filler valve closes all the way.
Robart Air Pressure
I use 100 PSI. most of my planes will hold air in the retract or brake systems for days... but one holds it only for half an hour. Either is fine, since the duration is well over the amount of time that the aircraft stays in the air.
I also use the CJM mini digital air gauges ... the readout lets me know when air pressure is dropping.
BTW, do remember to test the duration that your system holds air, with the gear in both the up and down position.
Gordon
Gordon
My Feedback: (108)
Robart Air Pressure
I have to agree with the no leak theory. My tanks will hold air for months. Mix up a solution of dish soap and water, and apply a little to all air joints with a Q tip and look for mini bubbles to arise. As stated befor, lube up all your O rings. Check the o rings on your controler as well, as they can and will leak. Good Luck, Dave.
