Dean's ant
RE: Dean's ant
If this is the real short antenna, I would stay away from it. If this is the one I am thinking of, it is designed for electrics and your range WILL BE RADICALLY reduced.
If you must use a short antenna, check out the Hayes "loaded" antenna. This is an 18" long antenna. I have used this on a couple of my scale planes to preserve the appearance and found my range reduced by only about 25'.
