Control rod upgrade for GP Cessna 182 ARF?
OR
I am working on a GP Cessna 182 ARF that I received for Fathers Day (2004) and I am thinking about replacing the stock control rods. They are solid wire in a stiff gray plastic tube which allows allot of slop/play in the rods. I am thinking about using either Dubro's Lazer Rods, Sullivan's Flex Gold-N-Rod (red & yellow) or Sullivans Semiflex Gold-N-Rod (blue & yellow). I have never used any of these systems but any of them sound better than the rods that Great Planes supplied. Please post with any experience with or knowledge of these products.
Thank you. Gene
Thank you. Gene
My Feedback: (7)
IN
RE: Control rod upgrade for GP Cessna 182 ARF?
I am not familiar with Dubro's Lazer Rods, they may be fine. On your plane, I do not recommend Sullivan's red and yellow except for throttle. The blue and yellow are ok but need to be supported as much as possible to avoid them flexing as well. The supplied push rods will also work very well if you support them with surrounding 1/4" balsa or 1/8" plywood.
OR
ORIGINAL: Mr_Scale
Thanks. Gene
