Using different servos with NiMH packs
Guys,
Why do some manufacturer's (i.e. Futaba) say things like "If using NiMH or Li-Po batteries, make sure they are capable of delivering sufficient Amps." Is it because the servo can draw a higher amperage than a NiMH can supply? Is there a difference between the amperage of a NiMH and a NiCd? Thanks all, Just curious because I'm running 4 high torque hitecs off of an 1800milliamp NiMH pack...
RE: Using different servos with NiMH packs
The internal resistance of NiMH batteries are higher than NiCads, so they won't deliver high current as well. You can double the packs, though and cut that resistance effectively in half. so you could run two 900 mAh packs, have better current flow, with the same capacity as one 1800 mAh pack. You can use a "Y" connector, or just hook the second pack to any available receiver channel. Just make sure the packs are in parallel, not series. Just add another 1800 pack, you'll have better current availability, and double your present capacity.
My Feedback: (41)
That's kind of a thing of the past. You can now get NiMh battery packs with less internal resistance than NiCd. Look at NoBS batteries on Hangtime Hobbies website. The internal resistance of the standard NiMh packs are 20 milli ohms. The new ones are as little as 5 milli ohms. I bought one for my Giant scale plane and they are great batteries that can handle a bunch of high torque servos.
