hangar 9 corsair retracts
hey can anyone give me a suggestion on how to properly set retracts on a hangar 9 corsair if the wheels are up they have to much slack and hang below the wing and the servo runs the battery down if you leave the out to long need help aftermarket retracts is a option if anyone knows a good set
ON, CANADA
RE: hangar 9 corsair retracts
Do you have a proper retract servo.? They shut off the electronics when they come to the end of the travel. They should go up and lock if the geometry of the servo is proper. A regular servo won't cut it.
