JR 6102 travel adjust vs D/R
Setting up a cap 580, having some trouble understanding how to set travel adjust and D/R.does one effect the other in the set up. thanx kevin
TX
RE: JR 6102 travel adjust vs D/R
Set up your throws to the maximum you want--this includes extending the EPA, if necessary. Make it as wild as you want. Then, set your dual rate up as a percentage (say, 70 percent or less) of that. Always set your maximum up first, then set the dual up as a smaller percentage of that--I find it works best that way!
