antenna lenght
RE: antenna lenght
pulqui, nearly all (I don't know of any exceptions) RC recievers whether on 27, 35, 42, 50, 53, 72 or 75 MHZ are all designed to use the typical 39 to 41 inch long wire for an antenna. While you might get some infitesimal improvements by varying this length a bit, you are more apt to have the opposite effect. You might want to check out Mr. RCcam's web sight as he has done some credible testing on changing antenna lengths.
