Mechanical Retract Dilemma
#101
Well MinnFlyer, I finally finished my CM Pro Mosquito and shot some footage of the mechanical retracts working. I have uploaded it onto YouTube and this is the link :
http://www.youtube.com/watch?v=20akGcE2Eho
All I need now is some clear weather to get it into the air. Some of the things I have added are, 2 x SAITO 56 four strokes, PCFS fuel feed pressure system, REWO Electronic Power Switch II - DUEL power supply powered by 2 x 5 AA 2000 MaH NiMH banks of batteries (especially good for mechanical retracts), the great mechanical retracts.
#102
Thanks for that Kieth.
One thing I would like to mention for anyone who views the video is that you'll notice a lot of flex in the pushrod, but this is due to the fact that the plane is upside-down.
The over-center spring is designed to help overcome gravity as the wheels come up. When the plane is upside-down the servo has to fight the spring.
#103
No worries MinnFlyer. The rod is actually bent to allow a more direct line with the rod going into the retract. I haven't been able get a nylon rod with the smaller diameter yet but you said the metal rod should be okay. The system works fine though. Cheers.
#104
ORIGINAL: MinnFlyer
When they are available, they will be sold through [link=http://www.3dxhobbies.com]www.3dxhobbies.com[/link]
Minnflyer,
Are you still making these retracts. I have tried without success to get in touch with 3dx hobbies. I am pretty sure I read this was where to buy your product. I have emailed and called multiple times with no response from 3dx. At this point I really have no desire to do business with them. The web site says the retracts will be in stock mid march, but it does not give a year....
If you could help me with locating your product I would appreciate it.
#105
Hi mewzella, I had the exact same problem and unfortunately minflyer can't help, because I asked as well. They are worth the wait but it is frustrating. I also nearly gave away the idea of getting them and going air BUT they did come available and I got my set. Hang in there......
#106
ORIGINAL: keith_porthedland
I guess my frustration is the total lack of response to phone calls and emails and a web site that never seems to be updated. Strange behavior for a company whose web site states
[/quote]
"Do understand even though we work many more hours then other companies, we aren't always around 24 hours a day and 7 days a week."
If they work more hours it must be in your time zone.
I will be patient as you suggest, unless I find another product and vendor who has an equivalent/better product.
Recently found the LADO products which look interesting.
Thanks again for the quick response.
#107
PA
And did I read earlier that current models of these retracts will feature a loop in the wire for more flexibility? I'm looking for a set now,but am leary of thier flexibility for hard landings. I dont want them bending all the time like the cheaper ones,and without loops to give some spring action.....I'd be curious to know how easy they are to bend. GP retracts have 3 loops and I'd be curious to see how they compare to my cheap 1 loop retracts I have now that bend fairly easy. And what size wires to they use? Robarts are 3/16" which are heavier then cheap ones. Not sure what GP's are.
#110
My Feedback: (117)
I'm sorry guys! i have been very busy with manufacturing the Airfoilz planes and the guy I had producing the retract totally screwed me and I'm still in search of a new manufacture source. I have no ETA, but I'm try hard to get them made.
#111
ORIGINAL: Furyflyer2
#112
My Feedback: (117)
GREAT NEWS!!!!! I finally have a new supplier and PLENTY of retract do in by end of the month!!!! Sorry it has taken 4-ever, but they will be worth the wait.
#114
My Feedback: (117)
RETRACT ARE FINNALY IN I HAVE 100'S OF THEM AND WILL BE FILLING ALL THE ORDER THIS WEEK!!!!!!! Put "RCU" in the user notes at time of check out for free shipping.
You can find them here-
http://www.3dxhobbies.com/Mechanical..._p/buz4060.htm
#115
NC
Hi Paul,
Earlier on in this thread you were talking about producing these with a single coil 3/16 strut and also the possibility of a steerable nose gear.
Any updates?
Thanks.
Any updates?
Thanks.
#116
They look good.
Are they 90degree retracts?
