Extensions for battery packs
My Feedback: (8)
CT
Do they make extensions for receiver battery packs like they have them for servos? I want to move my pack down the fuse to balance a nose heavy plane.
My Feedback: (506)
Just use a servo extension. For safety's sake look for the heavy-duty ones with #22 wire, and put some shrinkwrap aroung the plugs to keep them from separating.
My Feedback: (16)
GA
Extensions on the packs are not any problem so long as you use the HD wire. If you are using a lot of Hi-Torque servos, then I would recommend getting 18 awg high strand wire.
