Slimline Mufflers,OS,Magnum, need help
It looks like the Slimline OS 4-stroke 120 side mount muffler will fit a Magnum 120 4-stroke. Does anybody know if this will fit a Magnum??
Thank You
Thank You
RE: Slimline Mufflers,OS,Magnum, need help
Well considering that the Magnum engine is a clone of the O.S. a lot of the hardware and O.S. accessaries are useable on the Magnum engines. You can verify this if you know the thread and diameter of the exhuast mount.
My Feedback: (16)
The threads are the same on the smaller engines but I don't know about the 120 four strokes. I don't have my Magnum 120 with me. It is at my summer home. The OS 120 has a 14mm outlet in the head but there is a reducer threaded in there to reduce it to 12mm. Therefore the muffler is 12mm on the OS 120.
Enjoy,
Jim
Enjoy,
Jim
