Pnuematic Retracts HELP!!!!!
G'day,
I am about to order my very first set of retrqatcs, the Robart 520W1 set of 3 retratcts( Only because Spring air aren't available), and With the set they provide the X small tank,..my question is,....will this tank do? or will i need a bigger tank?
JJ
JJ
NY
RE: Pnuematic Retracts HELP!!!!!
JJ, from what I have read here you will get about 8 to 10 cycles per fill up. I have a set of air retracts on my P-51 but its only 2 cylinders, not 3.
Regards Mate!
Regards Mate!
Thank you for all your help,... I have just ordered the 521W1's from tower, (Firewall mount nose retract),..again thank you I appreciate it!,..
JJ
JJ
