Reload this Page >
Flying with floats
Flying with floats
Old 03-31-2006, 09:09 AM
mobflier
Default Flying with floats
When I modified my plane to accept floats, I positioned the CG of the floats under the CG of the plane. When sitting on the floor it will lean a little forward. Is this better than it leaning back? How much different will it fly? The plane is a trainer and I installed a Thunder Tiger F 54S, so it has pleanty of power. A picture of the plane can be seen in my gallery.
Old 03-31-2006, 10:07 AM
MinnFlyer
MinnFlyer's Avatar
Default RE: Flying with floats
Add (Or remove) weight to (from) the floats so that the plane's CG is the same as it is in a wheel configuration.
Set the floats up so the Step is right at or within 1/2" of the CG and the TOP of the floats should be -2 degrees (Minus 2 degrees) incidence with the wing at Zero degrees incidence
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
