Grass or Paved runway
RE: Grass or Paved runway
I chose "grass", but there should be a choice for "either". Our club has both, and there are times where one is better than the other. A small plane is easier to get up to speed on pavement, it doesn't catch the gear or prop in the grass, and even big planes are great off pavement, Landing might be more forgiving on grass if you screw up, but once you get the hang of it, pavement is my preferred surface there, too. Not as much braking effect due to drag on the wheels, less tendency to nose the plane over, but runway rash is more severe if you nose over or ground loop on pavement.
Then there are the WWI birds with a tail skid instead of a tailwheel. More abrasive, and prototypical flight for them is obviously off grass. The larger wheels aren't affected as much on grass anyway.
Lots of times, I take off on the paved strip and land on the grass one (they're side by side).
ORIGINAL: Richard L.
Plus, landing on grass will make you a better pilot.
Takeoff is easier on pavement, though, takes less time to accelerate to flying speed, but the tendency to veer left may seem more pronounced and occur more quickly because there is less drag on the wheels.
My Feedback: (16)
GA
On 600+ runways I like paved.
Grass is easier on the plane overall and allows you to stop quicker.
I like the challenge of hitting the line on landings.
My Feedback: (85)
I prefer grass runways myself. although i have some small electrics that would really be nice for a paved runway. The paved runways just intimidate me sometimes. because the landing just keeps rolling and you have to use s-turns to get it to slow down. Plenty of times in the last year i have wondered about the takeoffs and landings while learning on pavement or grass. seems like it would easier to take off from pavement as opposed to the longer spring grass. Anyone who learned on both during their first year of flying i would like their opinions on which they thought was easier.
Dennis
Dennis
ON, CANADA
Think for retracts then paved is best , also usually the paved is more like a runway , & is narrower than a grass patch , so you have to be a better flyer to get down on it than grass.
However i voted Grass , I have mostly big WW1 stuff & try landing cross wind on paved runways . Last year after 3 landing s across wise , my big 1/3rd Pup had the landing gear all bent a 3hour job to fix at home &&& the one wing tip was worn right thru from the paved runwayrubbing on it . SO Grass !!!
I choose grass... I used to fly in pavement but many times resulted scratched on wing tips or props (now I get green!!!)
Bye!
Bye!
I prefer Grass.
I still have fond memories of the smell of grass while out at the local site. The smell of burning castor oil also brings back memories.
We had a big square field off the side of our local airport, regulary mowed, good smooth condition, and you could always takeoff into wind if required.
Im not flying on paved at the moment but ground just as hard, and its giving my models a hard time.
WY
I'd like both. Since our field is located in the high plains desert area of Wyoming, paved is the only way to go.
Rich
Wyoming Wind Festival Jan 1 to Dec 31
Rich
