Reload this Page >
Enough room for carb?
Old 04-11-2006, 03:40 PM
Backwing
Default Enough room for carb?
This is what the carb of my Moki 1.80 on my Yak looks like. The front of the carb inlet sits flush with the lip of the cowl. The rest of the carb inlet sites inside the cowl.
Doy you think this will allow enough air to enter the carb? Or should I notch out a larger opening?
Old 04-11-2006, 06:32 PM
redfox435cat
redfox435cat's Avatar
Default RE: Enough room for carb?
have you tried running it on the ground yet? Looks to me like you doing to have to notch the cowl a little to get it in the air stream
Old 04-11-2006, 07:00 PM
red head
I just double checked my Moki in a 300 but it is completely clear so that won't help. Instead of carving, can you apply a bit of heat to the cowl by the carb inlet and possibly reform it a slight bit ?
Granted this isn't a Moki but I have a 46 that the carb throat is completely behind the cowl lip and it works fine, in fact I've had 4 planes with the same situation. Make that 6 planes. ENJOY !!! RED
Old 04-11-2006, 07:29 PM
JohnBuckner
JohnBuckner's Avatar
Your intake air is no problem at all however your outlet area for that pressure cowl appears to be non existant, hard to tell with this photo. this is what you need to worry about.
John
Old 04-13-2006, 04:58 PM
Backwing
Good idea Red Head, I might just try that.
I know I do need to do some surgery to get the proper outlet area. Your right, right now it is non-existant.
Thanks.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
