Reload this Page >
Towing Banners, has anyone done it?
Old 05-16-2006, 02:28 PM
donhef
Default Towing Banners, has anyone done it?
Hi Folks,
I would like to know if it is possible to fit a 40 sized trainer with a banner towing system. Nothing to huge, and I want to be able to take off with it and drop it off prior to landing, or at the other extreme, do a pick up from poles in the field (a la' Professor Fate). Any help would be appreciated!
Don
Old 05-16-2006, 04:44 PM
red head
Default RE: Towing Banners, has anyone done it?
Do a search for banner towing. There have been a number of post lately about it. ENJOY !!! RED
Old 05-16-2006, 10:05 PM
Deadeye
Deadeye's Avatar
I've posted pictures before, but RCUniverse will not let me upload any pictures tonight. It says 'missing field required' when I try to upload. If you find them, it is a series of 9 pages from the AMA magazine, posted by me.
Old 05-18-2006, 09:44 AM
donhef
Thanks Deadeye! That was a very informative article. I went ahead and printed it out for reference. I tried looking up the EK releasable towhook, but came up with bupkis. I think I'll go along with what one of the other Member's here did with a servo and plywood. I am so glad for the big braintrust here! Hopefully I can get this done before our Club's date with the public!
Don
Old 06-19-2006, 09:02 AM
milleratad
We used to pull banners with Duraplanes, Citabria’s, and a Cutlass model years ago. Only the Citabria was without a tow release. We did learn a few tricks to doing this with models.
First, the tow hitch: This can be as simple as running a pushrod through two pieces of ply (I’ll leave the rest of the build to your imagination) with a space to allow a ring to be secured with the pushrod extended. It’s important to slant the plywood so that when the line is under tension for the banner that it will release and not wedge against horizontal walls. We had a number of problems where the pushrod would retract but the ring would simply get stuck. Our hitches were located at the tail boom with the servo located forward to maintain CG. This meant that the pushrod runs parallel to the tailboom. Another hitch option would be to use a steal rod bent in a “U” shape with the pushrod intersecting the center of the ring, looking like the symbol “ψ”. This is a lower friction mechanism and should be more reliable as long as the ring is shaped correctly to minimize jamming. A paper clip shaped ring with a 45 degree bend half way should do.
Second, the banners: My brothers and I grew up doing real banners and we all fly commercially these days. So, when we were building these banners years ago we wanted to make them as real looking as possible. This was a lot of labor for something that gets beat-up pretty fast. Putting each letter on 8 strings and connecting to a rod between each letter is a little too much work. Taking a sheet or panel of rip-stop nylon is a bit faster and you can paint what you want on it. Any model banner needs several key features to keep it from twirling. A lead-pole with washers or other weights that protrude about 15-20 percent lower then the height of the banner. Caution: this can become a spear if dropped from very high. We attached the tow rope to the banner with 4 lead ropes. These attach to the lead pole at the top, 1/3, 2/3, and bottom of the banner. The leads are brought to a point and attached to the tow rope a little above the center of the banner, again to help keep it from twirling. The final feature is a sock. This is a split panel that keeps the banner from flapping like a flag in the wind. Sizing will depend on the size of your banner and model but the basics are the same. At the end of your banner sow or make a loop with your strings or straps. Attach 2 strips of fabric on either side at the end of the loop with a small space between them to allow the wind to inflate the sock and pass between the two panels.
Lastly, The pickup: A true test of your skill is a banner pickup! It’s hard enough to do a real pickup while seated in a Supper Cub or Citabria, it’s quite another to do this from 20 feet away without perspective. Not only do you have to do precision flying but you have a hook that will swing wildly and exacerbate your every twitch. We used large cutoff treble hooks with lead weight at the end of nylon string (again these can be dangerous). This was very flexible and difficult to control. On one occasion with a Duraplane I was a little unsteady and the hook caught the pole. The pole was well planted in the ground and ripped the plane from the sky. If this would have been anything other then a Duraplane it would have been pretty severely damaged. You might experiment with using real cable or something a little stiffer then nylon string to solve this or just practice a smooth approach. Also, make sure your banner is laid out down wind of you pickup. You should be pealing the banner up. If using a larger panel or billboard type then you can bundle it under the lead pole. If you stretch it out, a sudden pickup can rip it from the vacuum created as it tries to suck it off the ground. This is only a problem with really light material. Also, you can practice the “pull-up” followed by a heavy nose over at the top just as your tow rope gets to the banner. This is the smoothest on the banner and prevents you from stalling the model. If your banner is just too big then you have some altitude to try and release the banner and recover.
Enjoy!
Old 02-26-2007, 06:04 AM
aerialcameraman
I tow full size banners with a PZL Wilga, you could always try using the same method. (The snatch) is the best and most spectacular way to get your banner in the air and is also the safest. Attach a releasable short line to the tail of the model (about 15 feet long) at the end of this line put a grapple hook. Layout the banner with the rear end facing into wind and have about 20feet of tow line atached to the front end, the end of this line should have a loop which is drapped over a couple of short poles.
You then dive the model into wind towards these two poles and pull up. the action of pulling up throws the hook downwards to collect the loop. As the model climbs away the banner gradually peels off the floor in a smooth action. It goes up at about 45 degrees. The front end of the banner has what is known as the lead pole which is weighted at the bottom. this is all that is required to keep the banner upright. the back end of the banner has a small dragshute.
It's a crowd pleaser on the full size aircraft.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
