heli fuel for saitos
OH
I have been reading on other posts about using 30% heli fuel in the saito engines, I have a friend that flys helis so I asked if he had some I could try, gave me a full gal. of wildcat 30% to try and said if it works he has more at a very good $$ ( he switched brands and has over a case left) the question is, can I run this in 40 to 60 size 2 strokes with no problems other than the normal carb adjustments or can it harm the engine? I know they dont need that much nitro but at the price it's hard to turn down!
thanks, mike t
thanks, mike t
WA
RE: heli fuel for saitos
I ran cool pwr 30% for a year in my Saito 100 and it started to make some funny noises. It turned out that it's bearings were shot.
Saito charged me 60 bucks to replace bearings. I ran it as rich as possible also. If you like the xtra pwr and smoke and dont mind spending an extra 60 bucks, go for it.
My Feedback: (8)
30% heli will be fine in your saito... many folk's will run nothing less. I tried it myself and just didn't notice enough of a performance boost to justify the extra cost and the need to have several different types of nitro fuel on hand... this leads to your second question. Your probably gona have a hard time getting your 40 to 60 2 strokes to run well on 30% nitro... most sport class engines are not compressed to handle the extra nitro and run bad if at all.
If the price is right and you want to get the most possible power out of your saito with some cost of engine longevity and don't mind having 2 different %nitro fuels on hand then go for it.
John
John
My Feedback: (7)
MS
I have a saito 91 in a cub and I don't run anything but 30% through it. I've tried running my 15% I use in my 2 strokes and it just doesn't run the same. I can club the cub around at 1/4 throttle all day with 30% but 15% just doesn't seem to give it enough power.
My Feedback: (9)
CA
ORIGINAL: Jimmy Hoffa
3DAP,
Did you put after-run oil into the crankcase vent?
3DAP,
read FAQ #4 - what's a person to do??
[link=http://www.morganfuel.com/cp_faq.htm#4]after run oil[/link]
FL
I look at it this way, after-run oil may not help, but I guarantee you that it won't hurt anything either. I'm just trying to offer a helpful suggestion. Horizon Hobby recommends 30% and I've noticed that it provides a superior idle comparted to 20%.
Phillip
