Sig Epoxolite
Old 08-13-2006, 03:46 PM
Default Sig Epoxolite
Are there any products out there that are similar to epoxolite?
Old 08-13-2006, 05:12 PM
OldScaleGuy's Avatar
Default RE: Sig Epoxolite
I use Elmer's Carpenters Wood Filler for a lot of things that I used to use Epoxilite for. It is available at Home Depot. Lowes, Menard's, etc.
Old 08-13-2006, 05:41 PM
My Feedback: (20)
Stits Super Fil is an epoxy product that is lighter than Epoxolite and fairly easy to sand. www.stits.com I can highly recommend it.
Old 08-15-2006, 05:40 PM
Thanks fellows, good advice..
Old 08-15-2006, 09:57 PM
Campy's Avatar
I have also used Bondo.
I mix microballoons in the Bondo 1st, then after they are completely mixed in I add the hardener. Much harder than a "plastic wood", sands slightly harder (depending on the amount of microballoons), and weighs about the same or less.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
