PCM or FM Radio????
My Feedback: (44)
GA
PCM or FM Radio????
I need someone to explain to me the difference in PCM and Fm Radios. I know this may be easy stuff to some of you so please explain why jet flyers are using PCM radios???
Thanks in advance for your answers....[sm=confused.gif]
ME
RE: PCM or FM Radio????
If you use a pcm (pulse control modulation) radio there is a less of a chance of interference than fm . . . its a little more pricey but its worth it because usually a pcm radio can be set up to do either pcm or fm . . . so you get the best of both worlds
At its heart pcm is digitally encoded, PPM is analog. If theres interference the digital bit is either on or off, with ppm the pulse could vary and still be acceptable to the reciever but not necesarilly what you are commanding it to do.
Any high rf environments like helicopters and gas ignition engines PCM is the way to go.
