Slimline pipe, runs lean?
WA
When I run my OS max .61 with stock muffler it runs great, but after I put on a Slimline pipe it runs lean even if I back the high end needle valve two full turns.
After I plugged one of the two exhaust ports with my finger it idleled up and smoothed out. Thinking about stuffing one of the ports with a wooden dowl, has
anybody experienced this befor?[]
IL
RE: Slimline pipe, runs lean?
Id enlarge the hole in the pressure fitting on the muffler before id do that.
first id make that the pressure fitting is working not blocked.
