Radio --> ESC signal
My Feedback: (8)
The exact same signal that goes to a servo.
I would call it an analog signal. It pulses about 50 times a second.
The pulse width (duration) varies between 1 - 2 milliseconds depending on the position of the sticks. When the pulse is 1.5 ms, that is considered "center"
I'll try and get a picture from the scope.
My Feedback: (8)
This is from a 9C and 148DF receiver operating in PPM mode.
The scope is hooked to the aileron channel of the receiver.
This is a "train" of the pulses. Each pulse peak is right at 3 volts.
This is with a 4.8V pack
So wouldn't it be more of a PCM signal since it depends on pulse width? So it's a pulse that varies from 1-2ms that occurs every 20ms right? Is the output around battery pack voltage?
My Feedback: (8)
Some good reading can be found here.
http://www.wtp.net/DBEST/Sup7388tips.html
My Feedback: (8)
Ground (car) radios are exactly the same. The minimum and maximum depend on your radio and what settings is has.
You can make a simple circuit with a 555 timer to "simulate" a radio.
http://www.uoguelph.ca/~antoon/gadgets/servo3.htm
The official type of signal sent to the servo is PWM (Pulse Width Modulation). The speed controller takes this servo pulse and converts it to a higher-current signal at a different frequency (appropriate for a DC motor).
Nice scope pics, flatfour!
The different manufacturers don't use the same absolute standard. Either side of neutral with travels set to 100%, JR uses 0.4ms whereas Futaba uses 0.43ms. So a JR signal varies from 1.1 to 1.9ms, Futaba varies from 1.07 to 1.93ms. Multiplex uses 0.55ms, if recentred to 1.5ms this gives travel of 0.95 to 2.05ms.
They all use different maximum % travel, JR allows 150%, Futaba allows 140% and Multiplex 109%. Multiply the times by the % and lo and behold they all come to a maximum of 0.6ms either side of centre. 0.4*1.5, 0.43*1.4 and 0.55*1.09
So all brands allow a max of 0.6ms either side of centre, the difference is where within that range of 0 - 0.6 they define the 100% point.
Harry
Harry
