Spinners for 4 Strokers
NC
RCU Readers,
I've finally moved from the .46 size two cycle airplane engines to my first 4 stroker, a Saito 100. Question is, I've heard rumors that the plastic spinners I'm used to for the two cycle engines just won't cut it on the 4 strokes, because of greater prop kickback, double prop nut requirements, etc.
1) Is this true?
2) What is the recommended type of spinner to use. Should I look at the Dave Brown or Turn aluminum ones/ (pricey), or are there other alternates that you've have good luck with.
Thanks for your help,
Al Fuller
1) Is this true?
Al Fuller
VA
RE: Spinners for 4 Strokers
All my fourstrokes i use aluminum spinners, they are much more durable and just look cool. Ive tryed Dave Brown spinners as they cheaper than the truturns but since they are cast molded they will just shatter under impact. However truturns are turned under a lathe to shape they are much stronger and more true. Ive had a few mishaps with few of my planes and become relatively untouched. So I can just take them off and put them on a new plane without having to buy another spinner. Also truturn could custom make a spinner for you if you desire if you have a engine / prop combo that will fit your needs.
WA
To add to that a lot of fourstrokes can use the wider props and you have to modify the spinner to accomodate them. The problem is you can't modify the plastic props reliably so in that case it's best to get an aluminum prop that fits the wider props.
My Feedback: (13)
1 Post
I quickly found the torque needed to keep a 4-stroke prop on the shaft will distort the plastic back plate which keeps the cone from fitting. Metal back plates with a plastic cone are OK as they don't distort (Great Planes). Another negative with plastic spinner cones (especially with the CB brand) is they badly score from starter cones. If you hand flip that isn't a problem.
