Reload this Page >
Yellow Aircraft Sukhoi
Old 11-16-2006, 09:00 PM
Jlevin
My Feedback: (9)
Default Yellow Aircraft Sukhoi
Hi! I just picked up a Yellow Aircraft Sukhoi the other day, but I don't have the original manual. Does anyone know what the reccomended low and high rate throws are? Thanks!
Old 03-13-2007, 11:36 AM
marlinmad
Default RE: Yellow Aircraft Sukhoi
Hi
The Sukhoi Su-31m I have is the fun-key model that was sold by Yellow Aircraft kit No.
FK 2003 with a 72.5 wingspan engine size 1.08-1.50 2cycle!
My manual says as follows.
Aileron......... 1/2 up & down
Elevator........3/4 up & down
Rudder..........2'' R-L
Center of gravity .........4-3/4 to 5-1/4 behind leading edge of wing at the root.
Could you give me a heads up of what your using as far as and engine and servo's go thanks.
Greg hope the info helps you.
Old 03-19-2007, 02:12 PM
YSJunkie
I have the same Fun-Key Sukhoi sold by Yellow Aircraft, 72.5" wingspan. The instructions have the CG at 4 1/4 to 4 1/2. The airplane balances at 5".
Was the recommended CG changed at some point ? I'm a little afraid to fly it at 5" as it may be tail heavy.
Old 03-20-2007, 11:00 AM
marlinmad
Hi.
I dont know i'm just reading the spec's off the manual and for the C-G they give 4 3/4 to 5 1/4.
I like to go on the nose heavy side for the first flight and then i work it out from there!
I tryed to scan the manual but my scanner quit on me.
I havn't finished setting mine up yet. I'm into it now i bought this plane used and really couldn't get much info on it but i did get the manual that came with it.
I'm planning on puting a supertiger 2300 on it. The manual says to use standard servo's on it
but im thinking its a little big for JR-537 servo's. What are you going with as far as engine and servo's. Thanks Greg.
Old 03-20-2007, 03:46 PM
YSJunkie
My manuel makes no reference to the type of servo's. I called Yellow Aircraft and they said the CG should be 4 1/4 to 4 1/2 so I'm a little tailheavy. I'll have to move things around a bit. I'm putting a YS 160 in the nose and Hitec 5985's on all surfaces, Hitec mini on throttle mounted inside engine box.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
