Trike MLG position
Trike MLG position
Hi, I want to convert my Senior Telemaster to a Trike landing gear configuration. How far in % should the Axle line of the Main landing gear be behind the CofG? Thanks in advance for replies. Nigel H.
RE: Trike MLG position
Thanks for reply. I was hoping for a formula or % to fix the position, so the aircraft wont be too light/heavy on the Nose. I know trial and error is easy, but I hate drilling holes everywhere, to find correct position. Nigel H.
AZ
Nigel -
I have been successful with this method:
The stall angle of attack for most airfoils are about 16 degrees or lower.
Draw a line on the horizontal side view of the airplane from the CG location under the wing downwards at 20 degrees. Set the main gear wheel to touch the ground plane where the 20 degree line intersects the ground plane.
feihu
feihu
