Glow Fuel Cleanup
CA
Glow Fuel Cleanup
I'm sure its been covered, and I've been flying long enough that I should know.... But, what do you use to clean your plane after a day at the field? I think back in the 80's I used windex, honestly I can't remember how it worked. After getting back into the sport this past year, I've been using Soilent Green, I mean, Solvent Green, and it just seems to smear the oil residue around. Was told to add some alcohol to it, added some Jack Daniels, didn't notice any improvement on the cleaning, but everyone loved the smell. So, what IS the best cleaner?
As always, any and all input greatly appreciated....... Greg
RE: Glow Fuel Cleanup
For years I just used paper towels with 409. A while back someone tipped me off on using baby wipes. I get most off with just the wipes then finish up using a little 409. If you want you can put a little dish washing detergent in the baby wipe container. I look for the cheapest wipes I can find, aloe and fragrence does nothing for Monokote.
CA
Thanks for the comeback guys,
William, I was thinking about 409 or fantastic or one of those, but wondered if it affected the monokote? Any color fading or anything?
Also, the baby wipes, they're just alcohol right?
Thanks again, Greg
Thanks again, Greg
409 is just a surfactant (detergent) and I have never noticed any effect. I guess baby wipes are mostly alcohol. I like them because they are completely saturated.
I usually use a multi-purpose cleaner for glass and kitchen surfaces. They are supposed to cut grease fairly well. On occasion I use automotive quick detailer spray, like the stuff from Meguires, to really make them look nice.
IN
Simple Green. Cuts grease very well. Buy the big concentrate bottle & mix it yourself. $10 for a bazillion gallons (well, maybe not quite that much...but it's alot).
Chris
Chris
CA
Chris,
I've been using Simple Green for the past year now, and I find that it leaves a oil residue no matter what concentrate or how many times I spray\wipe it. Theres got to be a superior cleaning agent than this, that's my purpose of this quest ..... Greg
5 cups (40 ozs) water
1 cup (8 oz) rubbing alcohol
1/2 cup ( 4 oz) ammonia
2 teaspoons (1 oz) liquid dishwasing detergent
Spray on surface,then wipe with hand. You will see it foam. Then wipe off with a paper towel. Works great!
ORIGINAL: WILDCRASHWILLY
My Feedback: (9)
NC
Hi
Here is the cheapest formula, just water in a spray bottle, with a few drops of dawn dishwashing liquid, cuts grease and cost less then a penny I would think.
Bill
Bill
