Reload this Page >
Prop size for os 55 ax
Old 01-09-2007, 11:48 AM
Ian Prentice
Ian Prentice's Avatar
Default Prop size for os 55 ax
HI I have an cm pro extra with a os 55 ax because of noise restictions we have to prop up so which will give it the best performane a 13 x 7 or a 14 x 4 wide ? thanks
Old 01-09-2007, 02:40 PM
jaka
Default RE: Prop size for os 55 ax
Hi!
Depends on what airplane you have got.
Old 01-09-2007, 03:32 PM
alan0899
G'day Mate,
I doubt a 55AX will spin a 13x7 well enough to give good performance, I would try the 14x4, which is what I'm planning on using on my 61FX, on a Yak54.
I have flown my Diablo, with 61FX, running a 13x7, was ok, but a 12x8 was better, so a 55AX, may struggle, with the 13x7, & give good performance.
Old 01-09-2007, 04:38 PM
Ed_Moorman
Ed_Moorman's Avatar
I have a 55AX, but haven't flown it yet. To cut down noise, I feel you need to stay below 10,000 rpm. You also want an APC or a prop with tips like the APC. Definitely do not use a square tip prop like a Master Airscrew. They are more noisy.
Old 07-08-2007, 01:18 PM
yaron_k
My Feedback: (45)
I was trying first an APC 12*7 on my new 55AX, and now using APC 12.25*3.75 of a Great Planes Reactor.
Unfortunately I can't make the engine work well, and it keeps on "cutting" on me in midair, mainly when I throttle back.
I'm afraid to go with the 14*4 though the noise is quite high with the 12.25*3.75, but am afraid to add load which might make life even more complecated
Any ideas?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
