Aileron servo for bell crank setup???
I'm planning on setting up my ailerons with a single servo and bell cranks. I’ve taken a circular servo arm, trimmed it and am using two clevises to control the ailerons. (please see pic)
Any concerns with this contraption? I’m new to bell cranks and have always used duel servos on the ailerons.
I realize the travel will be off opposite throw, but we're banking / turning right? Is that a concern in your mind?
Thoughts....concerns....
Thanks!
Thanks!
TN
bell crank
That will work,make sure it gives your ailerons enough throw
up and down.I mostly use the longest one with six and cut
four off and use the other two.Then if it has to much throw
I can move it back a whole or two.
