Reload this Page >
HELP servos operated hi speed
Old 02-07-2007, 09:44 AM
Flying freak
Default HELP servos operated hi speed
does anyone know what comany makes a high speed nedddle valve that is tuned via servos.. i think the DF guys use them
Old 02-07-2007, 10:04 AM
Don M.
Don M.'s Avatar
Default RE: HELP servos operated hi speed
The only ones I have seen were made buy adapting a nose wheel steering arm to fit the needle valve. If the needle valve is mounted on the engine you best use a spring somewhere in the link. If the needle valve is remotely mounted away from the engine a solid connection may be OK. I made one myself many years ago to use on a troublesome Magnum .45, hooked the servo to the flap knob. Worked well but still a pain in the *** A fuel pump or a Cline reg. would be better.
Other than that check with BVM or one of the other jet guys. Although most are turbines now.
Old 02-08-2007, 01:01 AM
alan0899
G'day Mate,
OS make a servo operated in flight mixture control.
http://www.os-engines.co.jp/english/...s/parindex.htm
Page 4.
Old 02-08-2007, 06:50 AM
Don M.
Don M.'s Avatar
ORIGINAL: alan0899
G'day Mate,
Page 4.
Interesting web site - thank you
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
