Vacuum forming
IL
Vacuum forming
Any info concerning the weight of the plastic sheets, where to buy it, will a covering heat gun be too hot, how much vacuum is required or a lead to a source for this info will be appreciated. I would like to give vacuum forming a try and thanks.
GA
Vacuum forming
I did a search on "google" by putting in "vacuum form". You might do a search like that. Found a site that provides info to make a small vacuum form machine using a shop vac. Go to: www.halloweenfear.com/vacuumformintro.html As far as the plastic, just any kind of plastic will not work. Best to check with a plastic sheet dealer for that info. I used sell industrial temp controls in the plastics industry and called on vacuum form companies (they don't use temp control, just a reostat). They had a table/platform with very small holes in it, like an air hocky table, and had a mold(s)/die placed on it. Depending on the mold there may also be tiny holes in the mold itself. They suspended the sheet of plastic over it that was heated by a heating element(s) over the top of the plastic sheet. When the plastic sheet got the "right sag" (experience dictated that) they lowered the sheet on the table and pulled a vacuum. Saw everything from truck bed liners to tiny blister pack covers being molded. There are scale builders that mold parts a lot, such as canopys and motor cowls and maybe one of them can give a little more insite. In addition some folks mold (melt) small parts in their oven or toaster oven.
forming
tell me what your going to form, i can help you.........33 yrs sign bus.
tinker [email protected]
Vacuum forming
follow these threads. the were very informative:
http://rcuniverse.com/showthread.php...vacuum+forming
Both of these showed up when I searched for vacuum forming here on RC Universe. The first one is a step by step from Chad Vietch one of the fourm moderators. Good info.
Have Fun!!
Reid
Have Fun!!
Reid
CA
Vacuum forming
You can also check out this thread:
http://www.rcuniverse.com/showthread...875&forumid=60
I posted several replies to this thread concerning this exact subject and even posted several photos of a home-made vacuum machine I designed and use..
