Reload this Page >
AIR BLEED VRS IDLE SCREW ADJUSTMENTS
Old 02-19-2007, 06:19 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Default AIR BLEED VRS IDLE SCREW ADJUSTMENTS
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ I get confused as to where to set that low speed screw point against the high speed spray bar, should it touch or not with open throttle, heres a picture if its ok let me know thanks SOME PEOPLE SAY BACK IT AWAY OTHERS SAY IT SHOULD BE JUST THE TIP INSIDE THES SPRAY BAR OTHERS SAY TURN IT OUT UNTIL IT STOPS WHEN IT JUST MAY FALL OUT IF BACKED OUT ALL THE WAY SO MAY BE SOMEONE CAN SIMPLIFY THINGS WITH MY PICTURE. I KNOW ONE THING FOR SURE BECAUSE YOU CAN SEE THE LOW NEEDLE GOING INSIDE THE SPRAY BAR ONLY WHEN YOU SLOWLY CLOSE THE THROTTLE.
HOW DO I START THE IDLE SET UP POINT ,WHERE SHOULD THE LOW SPEED NEEDLE BE INSIDE THE SPRAY BAR OR SET AWAY FROM THE FAST SPEED SPRAY BAR INSIDE THE CARB. LOOKING INTO THE CARB OPENED ALL THE WAY, FULL THROTTLE POSITION ? Attached Thumbnails
Old 02-19-2007, 08:40 PM
Ed Smith
Default RE: AIR BLEED VRS IDLE SCREW ADJUSTMENTS
Screw it all the way in. Then you know it is in the wrong place. Back it out half turn at a time until the engine idle is somewhere close. Then fine tune with small adjustments.
Ed S
Old 02-19-2007, 09:03 PM
suzonka
My Feedback: (7)
suzonka's Avatar
ORIGINAL: Ed Smith
Ed S
I quess when the throttle is all the way closed then screw it in until it stops
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
