Funtana 100x engine choice
MO
Right now I fly the Funtana 100 with a Super Tigre .90 I have a new Magnum 1.20 2 stroke engine that I could replace the 90. Do you think it would be worth the trouble? Would there be a noticeable diffence in power and preformance? Thanks!!!!
RE: Funtana 100x engine choice
you will notice a difference so long as the weight of the magnum is not alot more than the super tiger. You will get away wilt using bigger prop pitch too so prop hanging will be better. You need to decide on what prop you want to use and what you want the plane to do. Hope this help`s
