Reload this Page >
Engine Mount Modification ? Opinions
Old 03-16-2007, 05:28 AM
rrragmanliam
Default Engine Mount Modification ? Opinions
Hey Everybody,
I have an aluminum engine mount thats a bit too narrow between the rails for the engine. It's a 40 size mount and I'm wanting to use an old K&B .61 engine. I'm considering sawing the mount in half down the vertical center line, then mounting it as two seperate pieces to get the correct rail spacing. Has anyone ever done this? Would I be better of just springing for a new .60 size mount? The engine will be mounted on a .40 size stick type plane.
All opinions welcome and appreciated.
Darren
Old 03-16-2007, 05:53 AM
MinnFlyer
MinnFlyer's Avatar
Default RE: Engine Mount Modification ? Opinions
You could probably get away with it. It's not the best way to go, but it should work.
Old 03-16-2007, 06:03 AM
Don M.
Don M.'s Avatar
All that to save $15.00 [X(]
Old 03-16-2007, 06:07 AM
Kaos Rulz
I'd do it and not worry about it.
Old 03-16-2007, 07:47 AM
SamD
For the $5 bucks it costs for a Hayes mount, I'd save the aluminum mount for another project. A lot of work to save $5 bucks....
Old 03-16-2007, 03:34 PM
aerowoof
sterling and sog used to supply aluminum t mounts in their kits.worked then should work now.
Old 03-16-2007, 03:43 PM
Tired Old Man
If the side rails are long enough, split it, bolt it up to the engine rails, and do the locating work on the firewall. Just make sure that both mount rails have the engine mounting holes in the same relative locations. That's the most difficult part of using a split mount.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
