Reload this Page >
help with hot wire saw please, proper output voltage?
Old 03-19-2007, 02:21 PM
uonlylivetwice
Default help with hot wire saw please, proper output voltage?
several people responded to an earlier post with saw plans, thanks very much.
following a suggestion I got a model train transformer off Ebay. It looked like the right thing at the time, but now I am uncertain based on the specs. hoping someone can confirm that this will or won't work.
it is a Railline 300.
specs are:
input 120 volt AC
output 17.5 V DC, 18.5 V AC
total output 5.5 VA
The plans suggested in the range of 5-6 V, so I thought I had it right.
Can anyone help? thanks a lot!
Old 03-19-2007, 03:15 PM
aerowoof
Default RE: help with hot wire saw please, proper output voltage?
the train transformers I have have a knob for adjusting the output voltage.start low and increase slowly till it cuts at the right speed
Old 03-19-2007, 04:22 PM
j.duncker
j.duncker's Avatar
If the output is constant voltage. [ I use a 12v car battery charger charging a battery as my supply] just vary the length of the cutting wire until it cuts at the right rate. I slid a croc clip along the extra wire until I got the right rate cut it off and wound it round a ST screw.
Crude but it works fine for me.
Old 03-19-2007, 05:15 PM
Ed Smith
Same here. I use only a car battery charger. No buttons or knobs just plug it and cut cores.
Ed S
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
