Reload this Page >
Inline fuel shutoff valves
Old 03-26-2007, 05:59 PM
paul64
Default Inline fuel shutoff valves
Does anyone know of a company that sells an inline fuel shutoff valve for glow fuel? Fuel tank on a plane of mine sits up higher than the carb. If I've had my engine running, and my fuel tank is full, and for whatever reason I should need to shut down the engine...fuel keeps flowing into the carb. Moving the tank is not an option. I do have another idea as far as solving this problem...but the shutoff valve is pretty much the option i'd like to go with 1st. If anyone could help me out I'd appreciate it.
Old 03-26-2007, 09:21 PM
Campy
Campy's Avatar
Default RE: Inline fuel shutoff valves
Just close the high speed needle valve.
Old 03-27-2007, 05:59 AM
Flying freak
you could use a regulator..
Old 03-27-2007, 06:34 AM
rwright142
rwright142's Avatar
I'm assuming your plane is cowled, otherwise you could just pinch the fuel line.
Old 03-27-2007, 07:04 AM
bkind
I Have used the B&B Smoke Valve with good results. It can also be servo operated.
Old 03-27-2007, 10:41 AM
jaka
HI!
Why not fix it the easy way by altering the tank position...that way your enegine will work fine ...otherwise it will not!
Pump or a regulator is an option though...but I don't use these myself.
Old 03-27-2007, 10:46 AM
rclement
rclement's Avatar
You might try Heliproz. Here's a link to one of the types of shutoffs they have. They probably have others too. [link=http://www.heliproz.com/prodinfo.asp?number=106455]fuel shutoff[/link]
Old 03-27-2007, 01:18 PM
2slow2matter
The problem with a tank that's too high is that if you fly inverted, it will lean out quickly--that's a bad time for an engine to flame out on you!!!!!!!!
Old 03-29-2007, 07:29 PM
paul64
Thanks for the tips guys. Have had no problems at all with engine performance...upright or inverted. Just looking for a company that sells a fuel shutoff valve...thanks!
Old 03-30-2007, 10:12 AM
js3
Does it need to be servo operated? They are very easy to make so don't waste your money. Pylon planes do this all the time.
Go to [link=http://www.jettengineering.com/faq.html]Jett Engineering FAQ page[/link] and scroll down to...
Question:
How do I make a sucker tube shutoff for my racer?
Old 03-31-2007, 05:32 AM
Countryboy
My Feedback: (25)
Countryboy's Avatar
ORIGINAL: paul64
"Tettra"
http://centralhobbies.com/Fuel/fittings.htm
#TET4314
Old 04-01-2007, 05:08 AM
paul64
Thanks for the web site link countryboy. That company carries the exact type valve I'm looking for
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
