Reload this Page >
Hobbico Tach Readings Make No Sense
Old 03-26-2007, 10:25 PM
Bosch232
Default Hobbico Tach Readings Make No Sense
I have a Hobbico tach that hasn't seen much use.
It gives completely unrealistic readings.
E.G.: I have a Zenoah G-45 that I ran tonight, and this thing was saying 13,000 rpm's. Yeah, right...
I changed the batteries, same results.
When I hold it up to a fluorescent fixture, it fluctuates around 10,000 or so, but will drift off to 12,000 randomly. It never zeroes in.
I don't remember what it's suppoed to read at a fixture, but I don't think 10k is it.
Would it matter if the fluorescent bulbs are new T-1's instead of the bigger older fluorescents?
Is this thing junk? [:'(]
Old 03-26-2007, 10:59 PM
DMcQuinn
My Feedback: (13)
Default RE: Hobbico Tach Readings Make No Sense
When set to 2-blade setting, it should read 3600 rpm when pointed at a light (in the US where the AC cycle is 60 cycles per second). Mine does this with both flourescent and incandescent lights. I think generally these units are OK, but you may have a bad one.
Old 03-27-2007, 07:02 AM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
I would agree that you probably have a bad tach. Call Hobbico (Tower) and let them know that it's not reading properly. Using a flourescant light to calibrate/test it is a pretty bulletproof method. If it doesn't read correctly then something probably wrong with it.
Ken
Old 03-27-2007, 04:07 PM
Bosch232
Well crap, I don't get it.
I brough it into the house to check it against some older flourescents, and it does indeed read 3600.
There is no way on heaven or earth that a G-45 is turning 13,000 rpm.
Old 03-27-2007, 04:14 PM
[]TEX[]
[]TEX[]'s Avatar
You can not use the Tach with flourescemt lighting that is why you are getting bad readings. I know for a fact that my H9 tach says in large type, "Use in daylight only, use under flourescent lighting will give false readings"
Hope this helps you
Old 03-27-2007, 04:27 PM
rcfury
rcfury's Avatar
I had a similar problem when i was running in my saito 125. With a 16.5 x 5 prop i was seeing well over 11k rpms. After replacing the batteries and making sure its still zeroed with a light, i was getting the same reading. With all the fussing i was doing with the tach, and killing valuable daylight i tryed it again. Then I saw normal readings. What actually happened is i was breaking in the motor in direct sunlight, which maybe caused wrong readings due to shadows . So maybe rotate the motor stand more in the shade and see what rpms you get. I bet thats whats going on with you.
Old 03-28-2007, 11:58 AM
gbrandt1
RC FUry: I like that wrecked plane pic. I cut the tails off of my yard darts and mount them on a wall. Looks pretty cool....constant reminder of checking your gear out before flying.
Old 03-28-2007, 02:01 PM
scratchonly
I often get false readings with my futaba digital tach when the sun is behind me. The flourescent lite should work with any QUALITY tach.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
