Reload this Page >
Mixing question from a Noob....
Old 03-31-2007, 10:54 PM
SportsterFan
Default Mixing question from a Noob....
I have a Futaba 6XAS Radio. I'm setting it up with My SuperSportster .90
I have two Servos for alierons (not in a "Y" harness) these plug into Channel1 and Channel6. I can use the Flaperon function this way. Next is the Elevators (Super Sportster .90 has split elevators) I want to run a servo for each elevator and use the 5th Channel and Mix it with Channel 2. Here is the issue channel 5 is a Gear Channel. I can only get the elevator on Channel 5 to only move one way. Does anyone know if I can get Channel 5 to operate as a "Normal" channel so I can use it for the second elevator Channel?
I've tried changing the SubTrim... no luck
Maybe Time for a different Radio
Old 04-01-2007, 01:57 AM
mvallyman
My Feedback: (32)
mvallyman's Avatar
Default RE: Mixing question from a Noob....
I believe on the 6xas you have to run both elevator servos on a Y harness and hopfully they operate close enough without mixing, this is how I did it on my 6xas with dual elevator servos.
On the futaba 9C you can use channel 8 for the second elevator servo and trim it separatly.
Old 04-01-2007, 07:09 AM
jetmech05
If you're a newbie, I hope this is a third airplane. This is too much airplane to learn on and probably too much airplane for a second aircraft.
Hope you have an instructor.
good luck
Old 04-01-2007, 09:59 AM
venom290
venom290's Avatar
I use that radio on my funtana 90( dual elev. servos). I have an inline mixer, not sure if thats the right name the right name for it, but thats what it does. Both servos plug into it and it has a small ajustment knob to center or line up the elev. halves. Works great.
venom
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
