Reload this Page >
Air pressure sensor for retracts..
Old 04-03-2007, 03:33 PM
Pit-Viper 1
My Feedback: (12)
Pit-Viper 1's Avatar
Default Air pressure sensor for retracts..
Was wondering if anyone has heard of or tried to make a sensor for air retracts that would alert the pilot to the loss of pressure in the system? Want to use LED's that will come on if pressure falls to about half giving you enough time to drop the gear before it's too late. Watched a friend have this problem with his 1/5 TP P-51 last weekend. Fortunately one gear came down on it's own resulting in a new prop and a little character to the wing tips only.
Shane
Old 04-03-2007, 04:25 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Default RE: Air pressure sensor for retracts..
There is a unit that will lower the gear automaticly if the air gets low, but I can't seem to think of the company that makes it right now. (CRS)
Old 04-04-2007, 12:22 AM
ho2zoo
Robart makes a pressure indicator that you can add to your retract system.
See it here: http://www.robart.com/air_systems/access.aspx
Also, Robart makes some gear that will lower automatically when they lose pressure. The company called Spring-Air made the original pressure-up, spring-down retracts. Robart just started making this type a couple years ago.
Old 04-04-2007, 05:48 AM
Flying freak
evan then unless you use a 2 way system so that the plaane is sending info to the ground your going to need one BRIGHT led to see it....
Old 04-04-2007, 09:50 PM
Sherpa FE
Spring Air retracts is the company that makes the retracts that automatically come down if it loses air pressure. They are located in Melbourne, FL and are VERY nice to deal with. Below is thier website.
http://www.retracts.com/
Old 04-04-2007, 10:04 PM
TLH101
My Feedback: (90)
TLH101's Avatar
ORIGINAL: TLH101
I was not refereing to Spring Airs or any other "spring down" system. Somewhere I saw a sensor that you could set to lower the gear if pressure was lost. It was adjustable for the pressure it would lower the gear. However, Spring Air retracts are about as "fail-safe" as it gets with air retracts.
Old 04-04-2007, 10:09 PM
Sherpa FE
ho2zoo
Sorry did not see that someone had already posted it.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
