4 stroke engines
IL
4 stroke engines
whats so good about 4 stroke engines because they are twice as much as 2 stroke engines. I heard that they save fuel is that true? But what else?
RE: 4 stroke engines
yes the save fuel as they fire half the time as 2 strokes they have more torq so they like swining larg low pitch prop (3D) also the sound. can you imagine that perfict warbird that is completly scale only to hear a sreaming 2stroke [:@]
IN
I have just started to use a four strokes this spring. I did so for the sound only. As for how much fuel they will save all I can really say at this point is that I took a two stroke out of the plane I put my four stroke in, the two stroke was a O.S.61FX and the new four stroke is the O.S.91. With the two stroke I could fly for 12 minutes and then land. Same plane and same fuel tank, but now with the four stroke I am able to fly 15minutes. If this will help any.
I rarely use 2-strokes anymore, but when I do, the three things I notice most are:
1) The crappy toy-like sound
2) higher fuel consumption
3) the God-awful slimy mess they leave all over the airplane!
Once you go 4-stroke, you'll never go back - unless you LIKE that slimey mess
Now before the 2-stroke guys jump all over me, i will admit that 2-strokes have their place. That place is not in any of MY airplanes if I can help it.
CO
ORIGINAL: Flying freak
CO
Mamma always said "If something's worth doin, it's worth doin' right."
Yeah, I can't afford that either but a guy can dream.
Back to the topic... Fuel consumption shouldn't be a consideration in my opinion. I've run both two and four cycles and the cost of fuel didn't cross my mind.
Yeah, four strokes have their place. It's nice to turn a bigger prop if you want to. Some people like the sound better. Some people mistakenly state that they are quieter.
But if you want to go fast, nothing but a two cycle will do.
[link=http://www.rcuniverse.com/magazine/newproduct.cfm?product_id=1835]Sound[/link] Here ya go. problem solved lol All I did was skake my head.
[/quote]
Sorry, but even a four cycle sounds ridiculous on a "perfict" (sic) warbird. Not much a modeler can do to duplicate the authentic warbird's engine roar.
[/quote]
[/quote]
[/quote]
Yeah, hearing a scale P-51 or Spitfire fly by with it's single cylinder 4-stroke singing out a perfect duplication of the sound of a 1,500HP, Rolls-Royce or Packard, 12 cylinder, Merlin really is...... really is...... really is NOT WHAT HAPPENS.
An overweight, underpowered, overpriced single cylinder doesn't sound any more like a Merlin than the lighter, more powerful, and more affordable type single cylinders. Not by any stretch of the truth or imagination.
How are 2cycles different from 4 strokes?
They are lighter.
They are measurably more powerful.
They are appreciably less expensive.
They are often easier to operate.
As for how the two sound? Beauty is in the eye of the beholder...... or in this case, between their ears. We recently asked a couple of visitors to the field to pick out the "best sounding" model. They all picked out the one airplane that had a gasoline engine in it. It was a 2cycle gasoline engine. You want an engine that runs clean? Get gas. Want an engine that uses less fuel? Get gas. Want an engine that sounds different? Get the ones that turn the biggest props the slowest. Gas engines do that too.
You want to get the most power and performance for the best price? 2 stroke, glow fuel....................
They are lighter.
ORIGINAL: js3
Oh, and BTW, nobody complains that they are too noisey
I have both 2-strokes and 4-strokes and I like them both. Regardless of which you personally prefer, there is one thing I have found to always be true: you get what you pay for. Buy a good quality engine from a reputable manufacturer and you'll have less frustration. I currently have two OS .46-AX 2-strokes. They are much easier to start and tune than some less expensive engines I have tried.
Heck, I never thought I woild say it but I even have an electric now on a little Yak-54 profile. It was odd ar first not hearing an engine but the little thing is a blast.
The smaller 2 strokes do doubt have an annoying unscale like sound, the 4 strokes do sound some better. But put on a large 2 stroke like a OS 1.60 FX, with a pitts muffler and you get a nice rumble instead of that high rpm scream. On larger war birds the 2 stroke sounds much better. As for speed, the 2 stroke is king. Also with proper muffler placement, one can mostly eliminate the slim with 2 strokes and 4 strokes. 2 stroke or 4 stroke, they both sure are a lot of fun!!
CO
ORIGINAL: MinnFlyer
No mistake about it. The latest version of the 91 surpass REQUIRES muffler pressure. But before that, I usually ran my 91's without any muffler at all - just a straight pipe. And I still run two of my OS 70's that way
ORIGINAL: js3
I do have a 91 4 stroke on my L-19 Bird Dog with straight pipe and it sounds fairly realistic, not too loud, but then I like noise, who wants a quiet airplane, the real ones are very loud. Most 4 strokes with a muffler have a stopped up sound, kinda like a possum blowing thru a straw.
I think one of the best sounding single cylinder 4 strokes is the Saito .56. It has a certain sound you can pick out from the others.
A 4 stroke Moki 5 cylinder sounds the best of all model engines that I've heard except for turbines. Nothing like hearing one of those either idling less than 900 RPMs or going full tilt.
My Feedback: (18)
ORIGINAL: gregziemba
With the 4 stroke, I really like the sound and throttle response. Although my ST90 with a Jett muffler sounds pretty cool too.
My Feedback: (19)
For those who hate 4 strokes:
http://mypage.yhti.net/~dmcdnld/4cycle.htm
For those who hate 2 strokes:
http://mypage.yhti.net/~dmcdnld/2cycle.htm
