Reload this Page >
PRECISION AEROBATICS & Aerocoat coverings?
Old 04-11-2007, 08:43 PM
shd3920
Default PRECISION AEROBATICS & Aerocoat coverings?
Has anyone ever heard of Precision Aerobatics covering material?
http://www.atlantahobby.com/shopexd.asp?id=5890
OR Precision Aerobatics Katana MD Covering? http://www.atlantahobby.com/shopexd.asp?id=6764
Can they be used on trainers? 1/2A scale? Or only aerobatic sport planes like the name implies? I want to try something besides Ultracoat, so does anyone have any info on this product?
Also can someone provide links to where I can purchase Aerokote covering?
Old 04-11-2007, 09:59 PM
bruce88123
Default RE: PRECISION AEROBATICS & Aerocoat coverings?
http://www.sigmfg.com/cgi-bin/dpsmar...70F.html?E+Sig
There is supposed to be 36 colors available. Contact Sig for more info.
Old 04-11-2007, 11:48 PM
shd3920
Found it, thank you bruce.
About 40 colors Aerokote
About 32 colors Aerokote Lite.
Any opinions on how this product is?
And about the Precision Aerobatics?
ORIGINAL: bruce88123
Old 04-12-2007, 07:17 AM
bruce88123
Never used any of it.
Sig doesn't usually get involved with bad stuff though. Class act there. No idea how well/easy it applies.
Old 04-12-2007, 09:05 AM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
I'm currently reviewing a Sig plane that is covered with Aerocoat. It pretty much behaves like Ultracoat or Monokote. If I had to choose one of those two I would say that it was closer to Ultracoat.
Ken
Old 04-12-2007, 02:27 PM
ChuckW
ChuckW's Avatar
I've used the Aerokote Lite a time or two. It's got a fairly dull finish (at least int he colors I used) but is otherwise a good covering. It's definitely low heat though. Too hot of an iron or heat gun and it will burn through. Even if it doesn't burn through, you can curl up an edge that will never lay flat again. As long as you are aware and keep the heat reasonable, it works just fine.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
