Reload this Page >
1.80 Saito Question
1.80 Saito Question
Old 04-12-2007, 01:44 PM
BANJOAIRPLANE
Default 1.80 Saito Question
Ok,here goes.How do you start this thing?I mean do you use an electric starter or a chicken stick?Or do you flip it by hand?
I tried my starter and it won't do it.I got it started with a chicken stick,but it didn't like it very much.It kept throwing my stick down the field![X(]Am I going to have to buy a bigger starter or can I safely flip this with a gloved hand?[:-]Any words of wisdom will be muchly appreciated!
Old 04-12-2007, 03:10 PM
bhole74
bhole74's Avatar
Default RE: 1.80 Saito Question
If using a chicken stick, rotate the motor CLOCKWISE to the compression stroke, then give it a flip in the same direction (clockwise). It will kick back in the CC direction. This may sound backwards, but it is much easier.
Old 04-12-2007, 03:22 PM
macdona
I start mine with a Kavan starter on eighteen volts. Never has failed me.
Old 04-12-2007, 05:31 PM
daveopam
My Feedback: (9)
daveopam's Avatar
I have a regulator on mine and cant prime it enough for a back flip. If you can that is the best way. For mine I activate the throttle cut function on my radio. This closes the throttle all the way. Then the starter will spin it. Once it gets to spinning I turn the throttle cut off. This returns the throttle back to idle and it will start right up. You could also do this with your throttle trim switch.
David
Old 04-13-2007, 04:29 AM
BANJOAIRPLANE
Ok,both the back flip which I have seen but never tried and the close the throttle method sounds like a couple of ways to try.I've seen some 24 volt starters and if I don't have success with one of the other methods soon,I'll look into putting out the cash.Thanks guys!
